Ford 3910 diesel tractor-Trouble shoot starting problem? Help!
   / Ford 3910 diesel tractor-Trouble shoot starting problem? Help! #1
RLH07
Richmond,Va
Ford 3910
Help!
I have a FORD 3910 diesel, old but low hours <600. Have had it for 13+ yrs. Do basic maintainence. Problem figuring out starting problem? New battery last year, replaced starter/solenoid,OEM ignition switch last year. Turn ignition switch to start and panel lights up but nothing-no click or starter turnover. Checked battery,charged, voltage 12.9 when off, earlier when engine was started voltage did not increase. Thightened fan belt and rechecked voltage while running and Battery voltage 13+. Ran and started without difficulty for several weeks and now starting problems. After ignition switch failed to start the starter, rechecked the battery Voltage ~12.9,Charged battery overnight and tried to jump start with battery charger in engine start mode, 100 amp setting, and no change. Turn ignition switch on no solenoid click and no turnover of starter. I have checked all the wiring connections-OK, I tried tapping the solenoid housing in case it was sticking and same results. ? where to go from here. Someone told me you can turn the ignition switch to the run position and then using battery cable type wire and check the starter by hot wiring it bypassing the solenoid. I wanted to get your opinion before I tried this? How can I check to make sure the battery has adequate amperage? I am losing the war against the vegetation as my tractor sits idle!
   / Ford 3910 diesel tractor-Trouble shoot starting problem? Help! #2
Just helped a friend with this today. Your tractor has a safety switch that goes to the high low shifter. Remove the cover and bypass the switch. That should solve your issue. But i would replace switch long term to keep it safe. Good luck.
   / Ford 3910 diesel tractor-Trouble shoot starting problem? Help! #3
By the way. Any pics of your tractor?
   / Ford 3910 diesel tractor-Trouble shoot starting problem? Help! #4
If sawtooth didn't solve your tractors starting problem then check/clean & tighten ALL FOUR battery cable connections.
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
RoGator RG1100C (A51039)
RoGator RG1100C...
2015 Ford F-650 XL Super Duty Ext. Cab Forestry Chipper Truck (A49461)
2015 Ford F-650 XL...
2014 Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
2014 Lay-Mor...
