Ford 3600
   / Ford 3600 #1
Howard1
Kubota B2920
An embarrassing question to have to ask but here goes. I bought an older ford diesel 3600. It is probably about a pint or more low on oil. The dip stick and oil filter is on the left side of the motor but I have looked everywhere I know to look and don't know where the oil cap is located to pour in more oil. The top of the valve cover has a vent pipe in it but not cap. any help will be appreciated.
   / Ford 3600 #2
if a true 3600 the oil filler cap is located on the timing cover right in front of the injection pump if a 3000 it is locate on top of the valve cover
   / Ford 3600 #3
   / Ford 3600
Thanks for the help. I had found that cap but looked like the injection pump was fastened to the side of where the oil would go in and i was afraid that might not be it. This cap on mine has a little handle that unscrews from the top of that cap and there is a rubber seal under the cap. Appears to be in the very same location as the red cap your post was showing
   / Ford 3600 #5
That would be it. I just thought the picture would help, since that filler cap was painted red. (maybe the owner couldn't find his either) :D
   / Ford 3600
Thanks a lot, was a great help, appreciate it.
   / Ford 3600 #7
ps.. time to order a set of manuals for that machine. lots of good info in there.. and they are fairly inexpensive... good investment!
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
Jacobsen Turfcat T628D Front Cut Mower (RUNS) (A50774)
Jacobsen Turfcat...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
