Ford 3600 rear remotes rebuild?
   / Ford 3600 rear remotes rebuild? #1
Zleviticus
Frankfort,KY
Ford 3600
I have the IT manual and owner's manual but i cannot find where there is an exploded view of the rear remote hook ups.
Do they make a rebuild kit for them as all i have been able to find are new ones which i do not need. Mine are leaking some when i have the hydraulics attached. Suspect o ring or something but cannot find how to take the stupid thing apart or sizes needed. I am hoping to fix the leak and them maybe just maybe go to a hydraulic top link as i only use the rear remotes when i have the large disc harrow hooked up. Everything else is PTO driven or old school "pull the rope to make it work". :laughing:
#4 in this picture, should be a simple change. Scroll down on the left side to "hydraulic system" then click on "05K03"
New Holland (36) - 3 CYL AG TRACTOR ALL PURPOSE (1/75-12/81) Parts Diagrams
Awesome Thank you,, thank you thank you!!
I could not figure out how in the **** the thing came apart. I think i have the correct size o rings so looks like i will be switching them out in between the T storms this weekend. No shelter to work under out there right now.
   / Ford 3600 rear remotes rebuild? #4
You shouldn't have to take it apart, get a dental pick and just take it out the back where the male plugs in.
It is one bolt to take apart. This way i can see if there is anything else that needs to be fixed on it. I think it may actually be missing the o ring. I thought about making a conversion hose from the pull out kind to the style on new tractors. However that will have to wait until everything else is fixed . LOL
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
