Ford 3600 rear remotes rebuild?
   / Ford 3600 rear remotes rebuild? #1
Zleviticus
Frankfort,KY
Ford 3600
I have the IT manual and owner's manual but i cannot find where there is an exploded view of the rear remote hook ups.
Do they make a rebuild kit for them as all i have been able to find are new ones which i do not need. Mine are leaking some when i have the hydraulics attached. Suspect o ring or something but cannot find how to take the stupid thing apart or sizes needed. I am hoping to fix the leak and them maybe just maybe go to a hydraulic top link as i only use the rear remotes when i have the large disc harrow hooked up. Everything else is PTO driven or old school "pull the rope to make it work". :laughing:
#4 in this picture, should be a simple change. Scroll down on the left side to "hydraulic system" then click on "05K03"
New Holland (36) - 3 CYL AG TRACTOR ALL PURPOSE (1/75-12/81) Parts Diagrams
Awesome Thank you,, thank you thank you!!
I could not figure out how in the **** the thing came apart. I think i have the correct size o rings so looks like i will be switching them out in between the T storms this weekend. No shelter to work under out there right now.
   / Ford 3600 rear remotes rebuild? #4
You shouldn't have to take it apart, get a dental pick and just take it out the back where the male plugs in.
It is one bolt to take apart. This way i can see if there is anything else that needs to be fixed on it. I think it may actually be missing the o ring. I thought about making a conversion hose from the pull out kind to the style on new tractors. However that will have to wait until everything else is fixed . LOL
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 John Deere 1653 (A52748)
2018 John Deere...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
