Ford 3600 no stabilizer warning light cluster wiring.
   / Ford 3600 no stabilizer warning light cluster wiring. #1
Ayce0841
850S
I have a green wire coming off each one of my idiot lights. Well there are 2 wires coming off each one but a single green off each one as well. And one has green/blk wire. Where do the green wires go to? And where does the green/blk wire go? This is a wiring nightmare! I will attach a picture if it let's me. Also NO WIRE DIAGRAM MATCHES AT ALL!!
   / Ford 3600 no stabilizer warning light cluster wiring. #3
I'm an electronic tech, but post is confusing. Not sure...are you trying to install an instrument cluster?
You could shine a flashlight in each hole to see what it says...what it's for.
One wire lights would have to have a ground where it plugs in.
   / Ford 3600 no stabilizer warning light cluster wiring. #4
Its not worth the time and effort running single replacement wires. Spend $50 on a new harness and be done with it.
Sorry, I am trying to get the cluster working again. A previous owner cut wires, rewired things together, etc... I know what the lights are for, just not sure where to connect the green wires. Do they all go together?
   / Ford 3600 no stabilizer warning light cluster wiring. #6
I searched Ford 3600 tractor wiring diagram...then images saw the schematics. I would follow that. I'd have to look at them when I get time...let me know.
If previous owner cut wires, things don't match, it will be difficult but can be done.a24432.jpeg3d4ee1e7a4cd659486bb7c8257463adf.jpeg
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
John Deere 870 (A50120)
John Deere 870...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
