Oil & Fuel Ford 3600 engine & hyd system oil
   / Ford 3600 engine & hyd system oil
Soundguy said:
i wouldn't use a S rated oil if this is a diesel engine..
No idea what an S rated oil is but it says suitable for petrol, diesel and turbocharged tractor & plant engines, 3-point systems and steering boxes, to more manufacturers specs than I can shake a stick at!
   / Ford 3600 engine & hyd system oil #12
Here in the states, an ENGINE oil is S or C rated.. Service or Commercial.
C rated oils are for diesel engines.
S rated oils are for gasolene engines.
this has nothing to do with the UTF fluid.. only the engine oil...
   / Ford 3600 engine & hyd system oil #14
now that's neat.
that's the first oil yet I've seen to carry a gas/diesel S/C API rating AND multiple specs liek the 134 spec for a transdraulic fluid.
interesting.
soundguy
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
BUSH HOG DISC (A58214)
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
