Ford 3600 Deisel Tractor
   / Ford 3600 Deisel Tractor #1
bosque
china spring texas
ford 3600 ih 856 caseih 685 mf175
This is my problem...while trying to change out my hydraulic oil in the rear axle..I removed the pan-head screw(part#38308s36-5/16-24x1/8) instead of the square-head level screw located above the pan-head. The pan-head screw will not screw in .....what was it connected to internally? What do I need to do to correct this mistake???? The tractor is 1981 3600 FORD(SERIAL NUMBER) C677896. THANKS FOR ANY HELP....BOSQUE
   / Ford 3600 Deisel Tractor #2
Welcome from VA
   / Ford 3600 Deisel Tractor #5
Welcome to TractorByNet!
We moved your thread to the Ford/New Holland Owning & Operating forum. :)
   / Ford 3600 Deisel Tractor #6
Well your suppose to remove the bottom screw. Is this what your calling pan head screw? The one on the side which is a square head is the full level check screw. The bottom one should go back in no problem.
   / Ford 3600 Deisel Tractor #7
Pretty common mistake actually. One you likely wont do again :)
That screw holds a bracket inside for the hydraulic suction tube.
To fix it, drain the oil out of your rear end. Remove the Left step plate (that's the Port side of the tractor for you landlubbers) and then the round cover behind it.
Look in there with a flash light and you will see what needs to be done.
However, you need someone to help you with this as it is very difficult to reach in there and hold that bracket in place AND get the screw started from the Right side.
So find a helper, give them a screwdriver and have them start the screw while you hold the bracket in place.
Very easy fix though. And no you didn't hurt anything but DO fix it.
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
