ford 3500 glow plug question
   / ford 3500 glow plug question #1
Treebob38
Sanford Michigan
ford 3550
I just bought a ford 3500. Have a question about the cold start system. It appears to have a glow plug and injector on the intake. Its not hooked up. Does anyone know how this supposed to work and if it is worth the effort to reconnect it.
Thanks!
   / ford 3500 glow plug question #2
Check your inj pump leak off line to see if it goes to a resv before tank return
Not to sound stupid but what do you mean by resv?
   / ford 3500 glow plug question #4
resevoir
   / ford 3500 glow plug question #5
I don't know if the 3500 is like my older 861 Ford, but that is the diagram I went by to rewire mine. Mine was missing the relay and the push button switch when I bought it. Luckily the heaters worked OK after rewiring.
Great! Thanks guys! As soon as I get the old girl here I'll be able to get.a.closer look.
Hopefully I'll be able to ask better questions.
   / ford 3500 glow plug question #8
I have one of these. It has a thermostart heater in the intake manifold. Mine was disconnected when I acquired it. I connected it up, and it did fine for a while. However, one time it stuck on and burned up the insulation near the connector. I figured that's why the previous owner disconnected it. I suspect a bad ignition switch. You should download an owner's manual from the CNH website.
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2015 Coleman Dutchmen 274BH Lantern Edition T/A Travel Trailer (A51694)
2015 Coleman...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
