ford 3500 boggin out
   / ford 3500 boggin out #1
gregsons
new york
ford 3500 / dultz allis/ IH 434
Thought i had this thing figured out, been workin on this 3500 for a while then last week took it out back bush hoggin and worked like it was brand new. then the next day take it out back was working fine for 4 minutes then statrted bogging out till it stalled. statrted it back up and it ran good for about two minutes. engine was runnin fine but when it was in a higher gear 5 and up it was moving slow then it would bog out after 2 minutes messing with the gas / choke has no effect when it started to bog. New gas is in it and i cleaned the sediment bowl out today. cant get the bowl to stop leaking now. oh yeah i need to jump this tractor all the time this problem comes and goes but, when i jump it it would fire right up now i got to crank on it for awhile till i see fuel leaking out the bottom of the holly carb.:confused:
thanks for anyhelp
Ok i read threw a few threads before i posted. I started to read the post titled "Engine quits"when i got to Jubilee i skipped to the next one, after posting this i re read " engine quits" and its my problem. too. i think i need a card rebuilt. now i have 2 more questions how hard is a rebuild should i do it myself. the most in deph thing i ever did was a intake swap on a 84 monte carlo, will i need to take the carb in to a shop? also where to get a rebuild kit for this just got back from napa and TS with negitive results.
   / ford 3500 boggin out #3
if it's a holley carb.. hit a cnh dealer for the correct kit.. have the carb number with you.
soundguy
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
2006 Victory Lane 36SRV 36FT Tri-Axle 5th Wheel Travel Trailer (A51694)
2006 Victory Lane...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
