ford 3500 boggin out
   / ford 3500 boggin out #1
gregsons
new york
ford 3500 / dultz allis/ IH 434
Thought i had this thing figured out, been workin on this 3500 for a while then last week took it out back bush hoggin and worked like it was brand new. then the next day take it out back was working fine for 4 minutes then statrted bogging out till it stalled. statrted it back up and it ran good for about two minutes. engine was runnin fine but when it was in a higher gear 5 and up it was moving slow then it would bog out after 2 minutes messing with the gas / choke has no effect when it started to bog. New gas is in it and i cleaned the sediment bowl out today. cant get the bowl to stop leaking now. oh yeah i need to jump this tractor all the time this problem comes and goes but, when i jump it it would fire right up now i got to crank on it for awhile till i see fuel leaking out the bottom of the holly carb.:confused:
thanks for anyhelp
Ok i read threw a few threads before i posted. I started to read the post titled "Engine quits"when i got to Jubilee i skipped to the next one, after posting this i re read " engine quits" and its my problem. too. i think i need a card rebuilt. now i have 2 more questions how hard is a rebuild should i do it myself. the most in deph thing i ever did was a intake swap on a 84 monte carlo, will i need to take the carb in to a shop? also where to get a rebuild kit for this just got back from napa and TS with negitive results.
   / ford 3500 boggin out #3
if it's a holley carb.. hit a cnh dealer for the correct kit.. have the carb number with you.
soundguy
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Pallet of Asphalt Hand Tools, Shovels, Rakes, Bru. (A52384)
Pallet of Asphalt...
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
