Ford 350 engine vibration
   / Ford 350 engine vibration #1
oldthreetimer
MA
Ford 850
My 1956 Ford 850 (not 350, as I posted a minute ago) has suddenly developed an engine vibration at around 1200 rpm. I've got it apart now, so I can't do other tests, but it vibrated at that speed even in neutral. An oil leak that developed at about the same time might be related or it might just be that I inadvertently overfilled it, because it stopped once the dipstick stopped showing a little bit overfull. A tractor mechanic doubts my theory, that it's a main bearing going, and my tests for play on the crankshaft pulley tend to agree -- they show hardly any play at all. He thinks it might be a clutch problem. Any ideas?
   / Ford 350 engine vibration #2
I had a car with a standard transmission, which would vibrate the starter off .... or loose, if you caught it in time. Turned out to be, the flywheel was out of balance. I believe, I had changed to standard shift from auto. ?? Or, I might of had the engine rebuilt.
Thanks for your theory. New info -- about the front-mounted hydraulic pump system. I found a bent bolt and some loose ones in the pto shaft and on the pump mount. That shaft is always spinning when the tractor is running. I wonder if the created enough wiggle to make the vibration.
   / Ford 350 engine vibration #4
I would certainly think, that could be the problem. Anything "spinning out of balance" is amplified.
   / Ford 350 engine vibration #5
agreed.. loose front pump could be it.
the clutch?
press it at 1200 rpm see if it goes away.. easy to test that. :)
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
