Ford 345c transmission swap - Options
   / Ford 345c transmission swap - Options #1
F2504x4
Ford 345c
Hello all-
My first post, but first let me thank all of you for the advice and knowledge received searching and reading these forums as a lurker for years.
Recently I purchased a 500 hour Ford 345c MFWD, PTO, 8x8 TC shuttle, industrial loader. I love the machine, and as expected with those confirmed low hours, it looks, works, and operates just like it should. I bought this tractor for a hobby farm as a general use, do-all tractor dedicated for nothing in particular.
I needed low to the ground and stable to work around our lake and hills, wanted a pretty high lift capacity to pick up logs for clearing part of our woods, run a brush hog to keep a field mowed, and mfwd because our property is mostly clay and every time it rains it's like working on ice and sludge. The 345c seemed perfect for me and I love it- mostly.... but as the subject suggests, I just don't like / can't get used to the 8x8 TC shuttle shift transmission.
The reason I want to replace it with something else is for a couple reasons:
1. I'm a traditionalist who has overtly and actively chosen to drive manual transmission vehicles my whole life and that's what I know and like
2. Running a PTO stump grinder and brush hog, I don't have the ability to "inch" or feather up against items by using the TC disconnect switch or shuttle lever. Not to mention I need to idle down before shuttle, which lowers PTO speed.
3. Transmission gets hot - cooks the operator. (even with TC in lockout mode) :)
4. Lastly, although it may never be an issue and just my paranoia, I don't like the electronics control aspect of the transmission and it scares me that the disconnect switch or shuttle lever may not operate correctly and I could hurt somebody or something
Back to the main question of replacing transmission-
1. Easiest - get a same era 6 x 4 transmission loader model industrial tractor (or just transmission) and swap it out knowing everything for a fact will work and have all the parts and it'll match
2. Get a 8x8 syncromesh dry clutch transmission from a 4630/3930/etc similar era tractor and hope it all matches up. (parts diagrams show same housing, mostly same gears, counter shafts, and synchros, but there are some differences. Transfer case for MFWD also shows same part number)
3. Crazy question - convert mine to the 8x8 synchromesh (as in, are there enough similar parts that is in fact what the engineers did? Replace the TC with a dry clutch setup and a mechanical reverser?)
4. Buy a 4630 or eqivalent and play mix-match and put all my 345c parts on it including loader and nose section....
I highly expect some people to say "too much to read, sell the tractor and get what you want" but if you are still reading - Well, I would, except low hour, original, clean, garaged 345's, 445's and 545's don't come up that often, and I'm particular, and mechanical enough with the proper tools to tackle doing this swap and have plenty of time and space.
I like the 8x8 mechanical shuttle idea the best, but I read that's a Kubota design, even though it shares many parts to what I have now? 6x4 appears the most simple, and probably most rugged, but lacks the ease of reverser lever... Anybody own have operated both and what did you like/dislike?
And finally, Can you get either of these transmissions rebuilt somewhere because the last thing I want to do is put a sloppy transmission with 5000 hours and a million cycles on it into a tight machine? Anybody have either laying around for parts, or want my 8x8 shuttle? :)
Flame away or give me your thoughts and options.
Thanks,
Tony
   / Ford 345c transmission swap - Options #2
I have a 345C also, for loader work or blade work, the 8x8 can't be beat, but as a regular use tractor, it's just not cut out for it. I'm lucky, I have a regular tractor for those times.
When and if mine fails, I too will be replacing it with a 8x2, I will be looking for a 3910, 3930, 4610, or 4630 because it's just gonna be a whole lot easier and cheaper to unbolt at the flywheel
and roll up the whole tranny back from your donor, if you get the 4610 or 4630 you'll even get the motor upgrade to boot! I always keep my eye out for one with a blown motor to be ready.
   / Ford 345c transmission swap - Options #3
Hello all-
Thanks,
Tony
Regarding the heat issue, I have a couple of suggestions. First make sure both radiators are clear. The front loader hydraulic revisor has a tendency to seep fluid and it ends up on the radiators. As a result, all dust and dirt will stick to the fins and clog them up. Use Krud cutter or some other good degreaser then use a hose or pressure washer to clean them up. If that did not fix the issue the next step would be to buy a heat shroud. The newer tractors had this, it is a black plastic shroud that fits over the top of your transmission housing. It may have been standard equipment on the 345D series.
Swapping out transmissions would be very expensive since you have to split the tractor. You may be better off buying another tractor that better suits your needs for stump grinding, or rent a stump grinder.
   / Ford 345c transmission swap - Options #4
As long as you have a Ford 3 cylinder straddle mount tractor you will not cure your heat issue. You might lessen it to a degree (pun intended), but any of them are hot after running a while at summer ambient temps.
If you decide on a transmission swap, be sure to get the flywheel from the donor. You do not want to have to find one after the fact.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A51242)
2015 CATERPILLAR...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
UNUSED FUTURE SKID STEER QUICK ATTACH MULCHER (A51244)
UNUSED FUTURE SKID...
2015 Ford F450 Service Body (A47384)
2015 Ford F450...
