3-Point Hitch Ford 340B w/ 3pt backhoe questions
   / Ford 340B w/ 3pt backhoe questions #1
jukenut
Hello fellas,
I am looking at a Ford 340B by me for sale recently. I don't know anything about the 340B, I want to know what you guys can tell
me about the 340's. A couple of question I have off the top:
1 - this will sound like a silly question, but I got side tracked when i was checking it out and for got to check if the seat adjustable,
I am a little tall, and I noticed I was a little uncomfortable with the seat being so close to the pedals and steering wheel. I am
pretty sure it is adjustable , most are on tracotrs.
2 - I understand Ford made 3 - 340 models.......340, 340A, 340B, don't know what the difference is.
3 - is it relatively easy to get parts for it.
4 - what is a fair price for it in pretty good condition
5 - is it a reliable machine, engine, transmission , etc. (it also has PTO and 3pt)
6 - are they a 12v or 24 v system on them.
7 - what is the approximate weight of it ( just curious, don't plan on towing it anywhere)
8 - I noticed when it was running ( it is a diesel) every once in a while it would jump or speed up rpm for a brief instant, like all of a
sudden something cleared in the fuel line ( it was a cold day when I tested it, below 25 degress F ). Is that common for them?
I am thinking it might be a dirty injector. ( overall it did run good). Supposedly it is not run very often, maybe it just needs to work in ?
9 - I opened the fuel cap and a seen a steady stream of fuel going into the tank from what I believe was the return line
(it was up by the neck of the tank). Is this normal.
Lastly, their is also a 3pt backhoe, I think by ARPS, anybody ever here of them .
Thanks
   / Ford 340B w/ 3pt backhoe questions #2
Hello fellas,
The seats on most of these tractors were attached to the lift cover with a couple of studs. The seats could be adjusted fore/aft on these bolts/studs if the seat itself is not adjustable. Easy modifications.
It's a generational thing. The 340 came first, then the A, then the B. The differences may have only been styling, maybe a transmission offering, as the basic vehicle remained pretty much the same.
3 - is it relatively easy to get parts for it. Yes.
4 - what is a fair price for it in pretty good condition Can vary geographically.
5 - is it a reliable machine, engine, transmission , etc. (it also has PTO and 3pt) Yes, it was a pretty reliable machine.
6 - are they a 12v or 24 v system on them. 12 Volt
sudden something cleared in the fuel line ( it was a cold day when I tested it, below 25 degress F ). Is that common for them? Not unusual
(it was up by the neck of the tank). Is this normal. Yes, normal.
Lastly, their is also a 3pt backhoe, I think by ARPS, anybody ever here of them . Arps was one of the earlier suppliers of aftermarket attachments and was reputable.
Thanks
They were good tractors. I wouldn't be reluctant to own one. It's a utility variation of the 3600 ag tractor with a front axle of greater load carrying capacity. Good luck with your pursuit.
Kubota BX2380 (A50120)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 FREIGHTLINER M2 106 22FT BOX TRUCK (A52141)
2022 FREIGHTLINER...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
