Ford 340B (Ford 6x4 Transmission) Help Needed!!
   / Ford 340B (Ford 6x4 Transmission) Help Needed!! #1
SixSpeed5
Dade City, Florida
Yanmar 359C, Kubota M135x/4630, Unimog, Deere 650/Ford 340B
Hey Guys,
I have a 1986 Ford 340B (Independent PTO) that I need some help with. It only has 1500 original hours on it, bought it with 1200 hours not too long ago. Sat around mainly. A while back it started to get fussy about getting into gear (from a standstill), it got where it was a little slow, to having to idle down, to where I would have to pull the engine kill momentarily to drop the RPM, to the point where I would have to hold the clutch in and start it in whatever gear I wanted to use. Basically was just getting worse and worse. I figured something was up, I had adjusted the clutch to no avail. I figured maybe the pressure plate had an issue. Well I finally got the tractor split today, that was sure fun. Everything in that darn clutch assembly looks like a million bucks. From the throw out bearing to the pilot bearing it all looks positively great. While I might have missed something, I definitely don't want to put it back together and have the same problem!
So....now I wonder...what is my problem? The ONLY thing I can think of is maybe something between the PTO shaft/transmission input shaft that might be binding and not allowing the transmission input shaft to slow down. Does anyone know if this is possible, or a known problem? I am looking at a parts diagram and am not exactly sure which part might be the culprit.
Any help is much appreciated! Mowing season is creeping up on my quickly! Thanks!
   / Ford 340B (Ford 6x4 Transmission) Help Needed!! #2
Pilot bearing seized; disc not free to slide on input splines. Disc warped; PP finger too high or linkage broken. Oil on disc.
UNUSED FUTURE FT850J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
