Ford 340B (Ford 6x4 Transmission) Help Needed!!
   / Ford 340B (Ford 6x4 Transmission) Help Needed!! #1
SixSpeed5
Dade City, Florida
Yanmar 359C, Kubota M135x/4630, Unimog, Deere 650/Ford 340B
Hey Guys,
I have a 1986 Ford 340B (Independent PTO) that I need some help with. It only has 1500 original hours on it, bought it with 1200 hours not too long ago. Sat around mainly. A while back it started to get fussy about getting into gear (from a standstill), it got where it was a little slow, to having to idle down, to where I would have to pull the engine kill momentarily to drop the RPM, to the point where I would have to hold the clutch in and start it in whatever gear I wanted to use. Basically was just getting worse and worse. I figured something was up, I had adjusted the clutch to no avail. I figured maybe the pressure plate had an issue. Well I finally got the tractor split today, that was sure fun. Everything in that darn clutch assembly looks like a million bucks. From the throw out bearing to the pilot bearing it all looks positively great. While I might have missed something, I definitely don't want to put it back together and have the same problem!
So....now I wonder...what is my problem? The ONLY thing I can think of is maybe something between the PTO shaft/transmission input shaft that might be binding and not allowing the transmission input shaft to slow down. Does anyone know if this is possible, or a known problem? I am looking at a parts diagram and am not exactly sure which part might be the culprit.
Any help is much appreciated! Mowing season is creeping up on my quickly! Thanks!
   / Ford 340B (Ford 6x4 Transmission) Help Needed!! #2
Pilot bearing seized; disc not free to slide on input splines. Disc warped; PP finger too high or linkage broken. Oil on disc.
1996 16ft Triple Crown Trailer (A51572)
1996 16ft Triple...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
