Ford 3400
   / Ford 3400 #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
Looking to sell My Ford 3400. Not exactly sure on the year. I am going to guess in the later years.
720 Front End Loader
3 cyl gas 49hp (which is More than the diesel was @ 46hp)
4400hrs
4 speed with Hi/Lo
Pie wheel weights(some missing)
Loaded tires
3 point hitch
Live PTO
NEW clutch, pressure plate, Throw out bearing, generator, battery, cap, rotor, points, condenser, plugs, wires(I have receipts for all this) with 25-35 hours on it
New seat
I have New tire chains on it.
A quick tach bucket and Forks
72" John Deere finish mower
3pt 7' scraper blade.
The tractor runs Great, with no smoke, leaks or oil usage
What do you think it is worth?
   / Ford 3400 #2
Very good tractor.
Basically a 3000 with a heavy duty front axle for loader work.
Might be rated 46/49 HP at the flywheel
But rated at the pto at 37 or 38 HP at the pto according to Nebraska Test # 881.
Yours is not pretty but I believe it probably does run good.
I'm going to just throw some numbers off the top of my head.
Tractor $5000
Finish mower $600
Blade $200
Chains $200
If you sell it as a package you will likely net less $ than if you sold it by the piece.
Package deal - maybe $6000
Prices in PA/NY North east are some of the highest in the country.
   / Ford 3400
Thanks. I have it listed for 5500 with the quick tack bucket/forks
   / Ford 3400 #4
post the serianl number and date code fromthe bellhousing or foil underhood tag and UD or I will give you the year.. might or might not help it sell better.. some people like to know that stuff.. ( collectors usually.. ) so may not help.. but it's free to find out. :)
   / Ford 3400
Ok, thanks. I'll look later today
   / Ford 3400 #6
I was going to say between 4 and 5k for the package.
   / Ford 3400
Yeah, not gonna happen
   / Ford 3400 #8
You asked.
   / Ford 3400
This is what came off the right side bell housing
3F015
C281398
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
