Ford 3400 Selecto-Matic
   / Ford 3400 Selecto-Matic #1
Russ1717
Batavia New York
New Holland tc33d
Pray I changed the oil and filter in the transmission and the oil was a light grey in colour. The vent to the transmission was open and able to breath. My question is where did all the moisture come from? The tractor gets used enough to evaporate the water, so why didn't it? Is this common with this transmission?
Any ideas I would appreciate it.
Russ
   / Ford 3400 Selecto-Matic #2
however it got in is unimportant at this point.
flush with some diesel in that oil.. change filter.. repalce with utf
Thanks soundguy! We will give it a shot.
   / Ford 3400 Selecto-Matic #4
work out ok for ya?
We are doing this on the weekend. Between work and life,
Time is short. I will be sure to let you know of our hopeful
Progress. Hopefully you will be still out there, for future questions. :)
   / Ford 3400 Selecto-Matic #6
Russ
Moisture gets in when the transmission cools it sucks in air and mositure. Unlike motor oil most transimission oils I have been told abosrb water, which seem to be my own experience also.
One note, this winter seems to have been a very bad one around here for moisture issues (I see your location is NY). Everything from our discbine, and all of our tractors come spring had issues with water in the oils. I ended up changing the fluid and filters in everything. Even things that were in the shed and not run over the winter. The trans on our 6605 that we have had for 8 years should have gone till next spring going by the hours and past history. Yet the fluid took in too much water this winter.
   / Ford 3400 Selecto-Matic #7
whenever you get to her, post back
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2012 Honda Accord Sedan (A51694)
2012 Honda Accord...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
9202 (A50322)
9202 (A50322)
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
