Ford 3400 loader fluid change
   / Ford 3400 loader fluid change #1
Biglurr54
Averill Park, NY
Oliver Super 55, 1965 Ford 3400
I'm going to exchange the fluid in my 3400s loader. I would like to get as much fluid out as possible because I have water in the hydraulic fluid. Any tips or tricks to get the most fluid out?
I know there is a paper filter and a composite filter. Is one better than the other or should I replace what is there with the same?
My breather appears to be a pipe plug with a small hole drilled in it. Is that the correct part or is there a better breather?
The loader is a ford 730.
   / Ford 3400 loader fluid change #3
I replaced my filter recently, and believe it was a paper one.
A pipe plug with a hole in it is NOT the correct breather!
I think Messick's will have the correct breather cap. It does not allow water in.
   / Ford 3400 loader fluid change #4
A 730 ‘should’ have the paper element. The composite filter is NLA. Raise the loader all the way, drain the reservoir, lower the loader without starting the tractor. That will drain the lift cylinders.
Rick. Perfect thank you. I appreciate it.
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
UNUSED FUTURE...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
