Ford 335 Industrial with 735? loader
   / Ford 335 Industrial with 735? loader #1
blue3021
DeKalb IL
Ford 335
Greetings! This is my first post on this site. Looks to be a lot of knowledgeable folks.
I have a Ford 335 with what I think is a 735 loader. One of the bucket cylinders is leaking, and I figure I'll pull it off and get it rebuilt. When I pull it off, I'd like to cap the fittings on the cylinders, and plug the fittings on the open hose ends. I know I could probably get by with some rags or plastic bags to cover everything up, but I'd rather just use some metal caps and plugs, and be done with it.
I looked through the service manual, and operators manual, and for the life of me, I can't find any specs on what size caps and plugs I need. I assume they're NPT fittings?
Any idea what size caps and plugs I need to cap off the hose and the cylinder?
   / Ford 335 Industrial with 735? loader #2
They are not NTP. A 735 I had several years back had SAE fittings in the cylinder and the hose end was JIC. I think they were #8 but can't swear to it.
Don't get metal caps anyway. Best to get the push on plastic caps that cylinders and hoses usually come with. Cheap as a match.
   / Ford 335 Industrial with 735? loader #3
See what size wrench fits the line and go to the hydraulic hose place and tell them you need a JIC cap and plug to fit that wrench size. That usually works. They are cheap; maybe a couple dollars each and are handy to
have around.
Gary
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
Cat TH407C Telehandler (A52748)
Cat TH407C...
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
