Ford 335 3 point hitch not working
/ Ford 335 3 point hitch not working #1
abletractor
Rochester, WA
Ford 335
I have recently purchased a 1976 Ford 335 industrial tractor with a 3 point hitch problem. It's not working. I have replaced the hydraulic pump which was bad and have opened the hatch to the 3 point hitch under the seat, inspected and cleaned most everything. I found no broken parts, just dirt oil. The pump is working to the auxiliary control unit because I can here the engine work. But no 3 point movement. Does anyone have experience with this problem that they can help me with?:confused:
/ Ford 335 3 point hitch not working #2
ford / newholland parts goto Document Moved or through messicks.com (might be easier)
i don't know your tractor, and the parts diagrams stink. it almost looks there is 2 pumps 1 for FEL (front end loader) and rear hydraulic remotes, then maybe one other pump just for the 3pt hitch. the second pump drawing fluid from the rear end? or am i just scrambling the part diagrams up?
are you seeing hoses run from "rear remote hydraulic valves" to 3pt hitch valve? or are the 2 valves complete seperate and no hoses / pipes running between them?
i am also wondering, if you may need the "PTO" engaged. for the 3pt hitch to work.
might suggest waiting for others to respond that know more about your tractor. i am just blah blah. trying to figure it out.
You might try this site for parts diagrams. Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
Well, I don't totally understand how this messaging works but if I am doing it right you will get a note telling you that I resolved my issue with the 3 point hitch. It turns out that someone? ahead of me had taken the tractor apart and put it back together incorrectly. I disassembled the 3 point hitch linkage and put it together the way it was meant to be, re-assembled it and it worked. The lesson for me in this is to not assume you have been told everything about the tractor from a previous owner and don't start replacing parts until you have checked the entire system first. I hope this helps someone.
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
GREAT DANE 96" X 45' FLATBED TRAILER (A64276)
GREAT DANE 96" X...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
213085 (A64276)
213085 (A64276)
Frontier Root Grapple (A64126)
Frontier Root...
20ft trailer (A61569)
