ford 3000 with desperate lift
   / ford 3000 with desperate lift #1
oilcooled
ford 3000
im paul from ireland im new to this forum.I have a ford with a real bad lift, its very jerky sometimes, and if you rev it sometimes it will lift less, also if you bring the handle up in stages it will lift better, but if you pull the handle up quick it wont lift well at all. i was thinking of rebuilding the pump cant see the differ between these two rebuild kits only the word MINOR or MAJOR, will the 2 kits fit the pump i refer to? is there much work in rebuilding a pump?
the lins to the kits
eBay.ie: FORD 3000 4000 4110 HYDRAULIC PUMP KIT. FHPK600-5 (item 150565419813 end time 20-Mar-11 20:26:51 GMT)
eBay.ie: FORD 2000 3000 4000 HYDRAULIC PUMP KIT. # CKPN600A (item 160548271598 end time 20-Mar-11 22:07:10 GMT)
also getting a lift cover kit and a filter
eBay.ie: FORD 2000 3000 4000 HYDRAULIC LIFT COVER KIT. LCRK65UP (item 150565414852 end time 20-Mar-11 20:15:38 GMT)
i find lift worse in the cold, pipes going to pump seem sound. the pump on it used to be serious what do you think is up?
:D
   / ford 3000 with desperate lift #2
I think ,you are going in the right direction ,but to fast....:D
1- Did you check the oil level
2- How old is the oil
3- Did you check o replace the hydraulic filters I have 2 of them in 2000 Diesel
Hope that helps
checked oil. oil fairly clean, will check filters next
   / ford 3000 with desperate lift #4
My hydraulic professor in college used to say 90% of 3 pt hydraulic problems is really a linkage problem.
Sorta sounds like some linkages in the lift cover are worn or binding.
   / ford 3000 with desperate lift #5
Do you have factory specified fluid for your climate, and filter? Any air bubbles in the fluid?
Have you checked pump pressure?
   / ford 3000 with desperate lift #6
i'd look under the lift cover, after checking oil, before I even glanced over at the PUMP.
soundguy
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2014 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT7EEB28740 (A51572)
2014 Ford F-550...
