ford 3000 tubing leaks
   / ford 3000 tubing leaks #1
casey didion
ford 3000
need help on a ford 3000. the hydraulic supply line (larger line out of the trans housing is leaking. the 90 degree alumnin fitting seems loose, how do I repair this fitting ? is it threaded into the housing and what holds the tube into that fitting.
thanks
casey
   / ford 3000 tubing leaks #2
are you talking about the compression nut at the pump?
use part numbers if you are unsure of the name.
online exploded diagrams are available at the nh parts website.
soundguy
the tubing fitting that is leaking is located at the bottom of the axel housing the part number si c7nne883a (elbow , left inlet tube, housing end). it seems loose and the parts book showes a O-ring on the tube end but what seals the fitting to the housing?
Thanks for the reply
Casey
   / ford 3000 tubing leaks #4
i'm at work away from my manual.. but I think that one is a press fit.
soundguy
   / ford 3000 tubing leaks #5
will take a look at the manual when I get home
Thanks, I do have a manual on order, I think I might just replace all the lower seals (brake shafts ,PTO, and hydraulic tubes. ) Is changing out the hyd. filter a big job?
Thanks for your Help. After I get this tractor repaired maybee I can pass help along.
Thanks
Casey
   / ford 3000 tubing leaks #7
the hydro filter ain't an easy one fer sure.. :)
soundguy
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
Kawasaki Mule 3010 (A51573)
Kawasaki Mule 3010...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
