Ford 3000 Tach Intermittent Failure
   / Ford 3000 Tach Intermittent Failure #1
tlj87
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
I have a 1969 Ford 3000 gas tractor with about 2410 hours on it. The tachometer recently stopped working. I pulled the gauge cluster, disconnected the tach cable from the tach and started the tractor. The shaft in the cable spun. I reconnected the cable to the tach and reinstalled the cluster. The tach worked for about 2 hours and the quit again. I repeated the above steps and had the same problem - it worked, then it stopped. Does anyone have any ideas, or is it time to replace the instrument cluster or something else?
Thanks in advance for any help!
   / Ford 3000 Tach Intermittent Failure #2
does the end of the cable have any wear? have you tried leaving the cluster out when it fails and see if manipulating the cable connection helps any?
most likely the tach coupling is getting flaky.. and yeah.. new cluster...
   / Ford 3000 Tach Intermittent Failure #3
ps.. i believe there may be 2 cluster types. the new style and old...
I did notice that the the face end of the cable itself looked like it had snapped off instead of cut square. The end was not rounded, however. If you can follow me...
Perhaps even if 1/8 or 1/4" of the cable broke off at some point, the tach would work for a bit and then stop after disconnecting and reconnecting? The best route could be to buy a new cable (cheaper) and see if the tach itself continues to function?
   / Ford 3000 Tach Intermittent Failure #5
if significant drive end of the cable is gone.. I imagine it has a hard time staying engaged...
Update:
I ordered a new tach cable and installed it. I ran the tractor for about 2.5 hours today it the tach/proof meter worked fine. I'll post again for reference if the tach stops again and I end up installing a new instrument cluster.
   / Ford 3000 Tach Intermittent Failure #7
that's about what i figured when you said the cable was damaged...
   / Ford 3000 Tach Intermittent Failure #8
Had a similiar issue on mine, I only needed to replace the coupling that joins the tach cable to the generator and the tach worked again. Mine was intermittent for a while then stopped altogether. Not sure what exactly went wrong but the new one had to be fiddled with and placed in a very exact position when tightened. Once we got it right it has worked for a few years now without issues.
Coats CHD-9551 Tire Charger (A50121)
Coats CHD-9551...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TV450B...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
