Ford 3000 rear PTO shaft seal leak
   / Ford 3000 rear PTO shaft seal leak #1
skytracker
Hale, MI
Ford 3000
I have been running the PTO a lot this season, brush hogging and cutting/harvesting hay.
Now I am leaking hyd fluid at the PTO output shaft. Probably a quart when parked overnight.
Bought a new shaft seal and cover gasket to replace. I haven't had to do one of these in a while. I will be draining the fluid tomorrow.
Anything else I should be looking for when I go in to replace besides inspect the shaft bearings??
Any input is appreciated.
   / Ford 3000 rear PTO shaft seal leak #2
Easy deal if it is a standard gear model ( non SOS )
1, drain rear/hyd oil
2, put pto selectro into gear
3, remove 4 bolts holding pto bearing carrier in
4, slide it out. if it is hard to pull.. put a drift or screwdriver thru the hole in the shaft to yank on.. can also take a hammer and hit the flange to spin it int he housing so it will break the rust and gasket bond. DO have a new gasket and pto seal on hand. you MAY need a new wear ring or bearing. but those usually last longer than the seals... and the new seal is a different size thant he old one by some small dimension.. so the lip generally rides in a slightly different location anyway.. ps.. lip / open side toward the oil.. the old seal will likely be a closed back seal too.
5, use a small screwdriver or a pair of trivers to pop the split ring edge out of the groove, and then walk it around and out of the groove using 2 screwdrivers. this is the ring in back of the bearing inner section of the pto shaft. the ring is a bit of a booger with tapered ends.. but once you get an end up and pressed over you walk it out like beading or debeading a tire with 2 irons.
6, lay a piece of wood on the floor, grasp pto shaft by the long inner end and tap the short outter stub end down onto the wood.. the bearing carrier and seal assy should drop off, leaving the pto shaft and wear ring and bearing assy in your hand.
7, inspect the bearing for play and the wear ring. sometimes the wear ring slips and allows bearing walking. there are retainer rings ont he shaft holding the back of the bearing... make sure they are in place. occasionally you find rings leaving wear marks floating out on the shaft. if the shaft and bearing and wear sleeve are goot, set it aside, and look at the pto seal and bearing carrier.
8, using a seal driver or large socket, drive the old seal out the back, and clean up the housing and seat the new seal in to the front split ring. grease the lip, now set the bearing carrier and new seal on top of the shaft and bearing assy, line it up by hand, grease the wear sleeve and bearing, now tap the long end of the pto shaft down on the wood, and the bearing carrier and seal will seat onto the wear sleeve and bearing... hold it together, carry it to your vice, open jaws and lower external stub end in till it is fully seated into vice and bearing carrier can't go anywhere, tighten jaws on stub end.. now slip that split ring over the top of th shaft end and walk it into the groove behind the bearing.
9, clean her up to remove debris, clean gasket surface on flange and housing with razor to remove all old gasket, etc, solvent.. etc. install new gasket dry, or with a smear of permatex if you feelt he need, slip back in spinning it by hand if it needs help to line up. line up gasket. install 4 bolts.
10, refill with oil..
done.
Thank you very much for the reply. It is standard 8 SPD/2 rev. I will get her drained tomorrow.
Then tackle the replacement. Have to find my big drain pan.
Will let you know how I make out.
   / Ford 3000 rear PTO shaft seal leak #4
good luck, and don't forget to slip the pto in gear.. i'm not 100% sure on that model.. but some have a thrust washer that can drop down if not in gear.. then you have to go in there with a broom stick with a handfull of thick axle grease on the end of it and get the thrust washer kinda glued up in place before you can re-stab the pto shaft.
Thanks for the reminder I would rather not have to do that.
   / Ford 3000 rear PTO shaft seal leak #6
Yup, not sure if your is one like that, but onto hurt to be carefull
   / Ford 3000 rear PTO shaft seal leak #7
Real nice thorough directions, Soundguy. Good one
Jim
   / Ford 3000 rear PTO shaft seal leak #8
hope it works out for him with no hitches.
Drained and half apart but NH dealer gave the wrong cover gasket have to go pick up the right one in the am. Then I will tear the carrier down and replace seal. With Soundguy's inst I think it will go OK. Let you know soon.
   / Ford 3000 rear PTO shaft seal leak #10
how in the world did the dealer get you the wrong gasket?? that pto flange gasket has only been used on thousands of fords! kinda like getting a wrong 4spd tranny top cover gasket... same one from 47 to 64 at least..
ps. you can cut one out of a manila envelope or folder with a ballpeen hammer and rubbing / tapping method if ya needed.
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
