Ford 3000 quits running
   / Ford 3000 quits running #1
Richard49
I bleed the injectors and get air. The tractor will then start but only run for 10 to 15 minutes. I bleed the injectors again and get air. Seems to be sucking air from somewhere but I cannot figure out where. Any ideas?
   / Ford 3000 quits running #2
Cracked hose or hard line between tank and pump, or loose fitting, though I'm sure you've checked those. Fuel cap not vented might add to the trouble. Does your if have a lift pump or gravity to inj pump?
Jom
Just put an inline pump on it but did not help.
Put a new injection pump on and she is back working again.
2025 SDLanch SDLE18P Gas Mini Excavator (A55974)
2025 SDLanch...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
MEYERS WELL PUMP (A52708)
MEYERS WELL PUMP...
202476 (A54757)
202476 (A54757)
ROLLING HAND CART & PUMP (A52708)
ROLLING HAND CART...
2011 MACK PINNACLE (A58214)
2011 MACK PINNACLE...
