Ford 3000 PTO Activity
   / Ford 3000 PTO Activity #1
clsmith
Hello All,
I do alot of reading on TBN, but haven't done much posting. Now I have a question for the tractor gods on here. I have a Ford 3000 that I had to have the 3pt hydraulics rebuilt and the PTO clutch replaced. The 3pt was hiccuping really bad and the PTO would not engage with out grinding. I had to cut the tractor off, engaged the PTO then crank the tractor back up with the PTO engaged. So, before the repair when the PTO was working properly, when I engaged it, it would start turning when I released the clutch just a little bit, and before the tractor started a forward or reverse motion. Now, since the repair when I release the clutch half way the tractor starts to move and the PTO doesn't start its rotation until I have released the clutch all the way. Is this the correct operation? I want to think not, but I need some direction as to where I need to go from here. Is this just and adjustment or do I need to carry it back to the gentleman that I had do the repair. Btw, the repairman is an older guy that retired from a Ford Tractor dealership so I assume he knows his stuff. Thanks in advance for you thoughts on this.
   / Ford 3000 PTO Activity #2
pto clutch should release before the the trans clutch i would try and adjust it
   / Ford 3000 PTO Activity #3
free play is about the only thing he can adjust on that double clutch.
sounds like something wasn't done right. wonder if the work done was a clutch replacement.. or just a 'repair' of some sort.. ??
soundguy
The guy replaced the pto clutch and the said the primary clutch looked fine. I didn't realize how much of a problem this was until I was cleaning out the edge of the woods around the farm. I use to be able to back in and out, but that's an issue now. Also I can't back over the edge of a ditch any longer b/c the bush hog won't start spinning fast enough. I"ll look in my I&T and see about the clutch adjustment. Thanks for the replies so far, they are really appreciated.
   / Ford 3000 PTO Activity #5
if he just changed the clutch and didn't check the springs in the pressure plate might be weak
   / Ford 3000 PTO Activity #6
yep.. no reason to go in there and not do the entire job..
soundguy
   / Ford 3000 PTO Activity #7
yep i always change everything out when having to split the tractor
   / Ford 3000 PTO Activity #8
some people forget the 3$ input shaft seal..
soundguy
   / Ford 3000 PTO Activity #9
i dont know why u wouldn't change it unless u like spliting the tractor alot
Thanks for all the replies everyone. I think I'm gonna give him a call and see if he'll check it out, since he was the one that worked on it. I have I&T manual, and I consider myself mechanically inclined, but I don't know if I want to tackle such a large job and end up screwing something up. I've replaced clutches in vehicles b/f but never split a tractor. Thanks again for all the replies, they are greatly appreciated.
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
