Ford 3000 Lift Issue
   / Ford 3000 Lift Issue #1
RickandTinaWms
Hello,
Our 1965 Ford 3000 has been down for about 9 months. When we started it up today the lift won't work. It was working fine when we last used the tractor.
I don't know where to start.
Will you help me know what to do please?
Thank you,
Rick
   / Ford 3000 Lift Issue #2
You could start by checking the hydraulic fluid level. After that there is probably a screen which may be plugged. It's old enough it may not have a hydraulic filter as such.
   / Ford 3000 Lift Issue #3
I have had similar issues on our 3000. I dug into the top chest and found everything was spotlessly clean, plenty of oil and so on.
I am pretty sure that my problem was a air leak and the system was loosing it's prime. I replaced all the seals in the chest and on the pickup pipes.
After bleeding the system it seems to have been ok.
   / Ford 3000 Lift Issue #4
I had some similar hydraulic lift trouble on a Ford 2000 from that era. I think that the inlet filter was plugged. Rather than cleaning/changing that filter, which involved a bit more work than I was willing to invest in that machine, i just added about an extra 1/2 gallon of hydraulic oil. That allowed the flow to get into the pump using another path (over the top). I ran it several years like that with no further issues. Whenever the lift started to act up, I would just pour in another quart or so. Hydraulic oil is cheap.
   / Ford 3000 Lift Issue #5
At the pump is 2 steel pipes.
Clean it and seal it with a bit of sealent like silicone.
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
