ford 3000 lack of power
   / ford 3000 lack of power #1
handyman41
Lancaster sc
ford 3000
Ford 3000 dirt in fuel system new tank new filters new injection pump and injectors. runs good with no load any load and it starts to die rev up still no power
   / ford 3000 lack of power #2
What injection pump do u have.?? CAV/Delphi or SIMMS.??
If it’s the CAV.. there’s a timing line on the mounting ear.. that line lines up w degree marks on the block..
MAKE SURE the pump line lines up w “0” degrees on the block..
Hope that helps..
   / ford 3000 lack of power #3
Sounds as if inj pump isn't timed correctly especially if there's a good supply of diesel getting to IP
Hope that helps..
ford manual says line up with o. installation says 19 bdc have tried it full range of movement not much diference.
It also gives off white smoke on startup and until warm, is not losing any water.
yes, didn't have front open can't see any way gear can rotate
   / ford 3000 lack of power #6
Which inj pump does your tractor have(Cav or Simms)?
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
City of Lakeland (A51691)
City of Lakeland...
