Ford 3000 Instrument Cluster problem
   / Ford 3000 Instrument Cluster problem #1
davka
Ford 3000
Ford 3000, 1966, 3 cyl, gas: The tractor is clean with no rust and runs great. Of the 5 indicators in the Instrument Cluster, ONLY the generator light works. The oil light, temperature gauge, fuel gauge and tachometer do not work. I want to get these indicators performing again. Any idea if there is a common denominator causing the 4 indicators to not work while the generator light works normally? How would I diagnose this problem?
   / Ford 3000 Instrument Cluster problem #2
The tach and hour meter are cable driven.
The temp and fuel gauges are powered by a voltage stabilizer attached to the rear of the cluster housing. The charge and oil lamps share a common 12v supply.
You have multiple causes for the various concerns.
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2016 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2000 Trail King TK70SA-48.2 T/A 43 Ton Step Deck Trailer (A49461)
2000 Trail King...
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
