Ford 3000 Hydraulics
   / Ford 3000 Hydraulics #1
cbarlandandcattleco
north richland hills, texas
ford 3000
Tried to use the post hole digger on my 1970 Diesel Ford 3000, The auger went down to China and the tractor did not have the hydraulic power to pull the auger out of the hole. Also I discovered the digger only goes clockwise and wont go counterclockwise. What am I doing wrong. Any suggestions would be greatly appreciated. :)
   / Ford 3000 Hydraulics #2
I have done this too, You just let your 3 point hitch down slower so that the auger can't take as big a bite as it's drilling the hole. All I do when I get stuck is screw the auger out with a big pipe wrench.
   / Ford 3000 Hydraulics #3
If the auger is driven by hyd, it will be reversible.
If it is a gear box only auger it will only turn one way when using PTO.
   / Ford 3000 Hydraulics #4
1, don't let augers run at pto speed. most people run them at IDLE
2, take small bites and clean the hole often.
3, take small SHORT bites.
4, if you like running the pto faster than reccomended and just let it screw all the way down into the hole, don't complain that your tractor has bad hyds.
5, If you practiced #4 above, then time to buy a BIG pipe wrench so you can unscrew your auger ( or dig it out with a shovel ), then, refer to #'s 1-3
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
Galvanized steel Fence (A53424)
Galvanized steel...
2012 MACK CXU613 (A55745)
2012 MACK CXU613...
New/Unused 10ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 10ft X...
