ford 3000 hydraulic lines
   / ford 3000 hydraulic lines #1
ncmike
North Carolina
2003 JD 790
Need to replace seals on rear of both ridgid lines from hyddraulic pump. I already have pump off of engine but I think both lines are leaking by brake arms. I appreciate any help or tricks that you have...Thank You
   / ford 3000 hydraulic lines #2
If the seals are leaking, replace the seals. If the pressure tube has a groove worn in it from the washer in the pressure nut, replace the tube as well. If the suction tube is kinked or cracked, replace it. All these parts are available new from New Holland. Know your tractor's unit code or be very familiar with the style of tubes you have as there are two styles. If these are the "tricks" you were looking for, Happy Halloween!
Thanks Rick, I am a rookie w/this tractor and didn't even know what the lines were called but I need to know how to get these lines off to replace the seals and O rings, again thanks for any help.
   / ford 3000 hydraulic lines #4
It helps to have a service and repair manual for your tractor... that said, Hit the new holland web site. then north america, then parts .. then search for parts.. search for your 3000 pick it from the list.. then pull up the hyds and or rear sections.. and look a tthe exploded diagrams provided.. along with the part numbers and descriptions.. should help you a bit.
soundguy
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
