Ford 3000 hydraulic lift problem
   / Ford 3000 hydraulic lift problem #1
belandon
Albany, ga
Ford 2000
I have a early model Ford 3000 that set up for several years. Lift worked then but not after I got it running again. Control lever has no tension on it. Any suggestions where I should start?
   / Ford 3000 hydraulic lift problem #2
check to see if you have oil in the rear/hyds sump. pull plug under seat on 3x5 cover and crank over to see if you have oil prime. next. check in draft and position control... if all that checks.. and nada.. get a top cover kit and pullt he top cover for a looksee.
Thanks. I will check it.
   / Ford 3000 hydraulic lift problem #4
top cover kit with gaskets and orings is usually pretty cehap. like 15$ or so. or was a year or so ago..
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2019 FREIGHTLINER...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
