Ford 3000 Hp?
   / Ford 3000 Hp? #1
Anonymous Poster
Epic Contributor
I have a '65 Ford 3000. The books say it has a 47 HP motor and 38 HP PTO. When shopping for implements that use the PTO should I use the lower rating to make sure my tractor is properly suited to the quip?
   / Ford 3000 Hp? #2
The lower rating, 38HP, is the spec you use when buying PTO equipment. PTO equipment (bush hogs, tillers, etc) will spec a required HP and the HP they are talking about is the PTO HP. The gross HP is the total HP of the engine, but there is some loss in the drivetrain, so the PTO HP is always lower. Older tractors, such as a 1950 JD B, only spec the PTO HP, but newer ones spec both.
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
