ford 3000 generator
/ ford 3000 generator #1
jgrieve
my dad has a ford 3000 with a lucas generator which is not charging. The plate on the back end of the gen is broken. This is the back cover and the rear mounting bracket. Where can I get a replacement bracket? I would like to replace with a alternator but the tack drives from the generator. Is there any other way to drive the tack?
/ ford 3000 generator #2
yep.. you can grab a suitcase of cash and get a delco 10DN with a tach drive and external regulator.. OR.. you can just have your gen rebuilt at a rebuilder. OR you can buy a new replacement model.. I see alot of indian models... I got a spare one on the shelf from india.. I'd normally guess that it wasn't as good as oem.. but then oem was lucase.. so.. :) the indian one might be better.
seriously though... new gens for the 65+ models are easy to find and affordable.
Discount Tractor Parts and Manuals for Older and Antique Tractors System&r=mcats
a whopping 89$
Generator, 12 Volt - For models (2000, 3000, 4000, all after 1965 gas or DSL engines), (620, 8000 both 1968-75 with DSL engines), 9000 1968-1975 with DSL engine. (Part No: C9NN10000A)
or. swap your old pulley over and tach drive and pay 79$
Generator, Less Pulley & Tach Drive - New Generator 12V, 22 amp - 1965-75 2000, 3000, 4000, 5000, Gas and Diesel, (620, 622 1967-74), (7000 1971-75 w\ 4-256), 1968 All 8000, 9000 series (up to Dec\1969). INDUSTRIALS: 2110LCG, 3400, 3500, 3550, 4110LCG, 4400, 4500. LESS pulley & tach drive. Pulley is available (see p\n C5NF10196B). Tach Drive available (see part #C5NF17B282B). Replaces Lucas 22756. (Part No: C7NN10000C)
http://www.ytmag.com/store/parts/pics/wm_C7NN10000C.jpg
soundguy
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
2004 John Deere 330 CLC (A61166)
2004 John Deere...
New/Unused SD Lanch SDLGC100 6-Seater Electric Golf Cart (A61166)
New/Unused SD...
PAIR OF 10' RAMPS W/10' EXTENSIONS (A62131)
PAIR OF 10' RAMPS...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61568)
1998 Fontaine...
