Ford 3000 Generator Question
   / Ford 3000 Generator Question #1
loy44
Peoria IL
Ford 3000 Diesel
I have a Ford 3000 diesel and have replaced many parts including a new generator (but not the regulator). I have polarized the generator. The generator light comes on brightly when it is at idle and also comes on dimly when operating above 1500 rpm. Should either of these happen? Is the regulator the problem?
   / Ford 3000 Generator Question #2
Likely causes are the regulator or wiring problems. The last tractor I worked on with that system had symptoms that led everyone towards the VR, but actually the wire from the VR to the generator armature was shorted to ground. Not broken, just shorted to ground.
   / Ford 3000 Generator Question #3
easy to check with jumper wires and / or a vom and test lamp to verify the wire harness. after you know it is good, do a full field test. jumper bat to field.. see what it does with the charge lamp.. andalso to bat volts... make sure vreg and genny are both grounded well..
IMHO.. i'd never replace a genny and NOT get a new vreg...
soundguy
   / Ford 3000 Generator Question #4
soundguy
The situation I referenced was unique becaust the wiring ohmed out fine while doing a basic wire check. The offending conductor just happened to have a dead short to ground as well, without causing damage to either the VR or generator. I put a front harness on it, repolarized it, and was done.
   / Ford 3000 Generator Question #5
It's a great point you brought up.. many people overlook the harness. I had a friend that was killing alternators in his late 80's model compact car every month.. I finally went over to his house to see what his problem was. the charge line had a crimp connector with a round terminal end to go onthe charge lug at the alt.. it was badly made and a SINGLE strand of the 10awg wire was actually making contact.
I imagine that poor alt was charging at high to try to bring up the bat volts it saw as low onthe bat sense line.. basically was charging itself to death... yet still leaving the car with a low battery most of the time.
Ironically a 59 cent connector and 30 seconds of soldering solved his problem..
soundguy
Thanks for the info. When it warms up a bit I will go out and start looking close at all the connections. Probably just buy a new VR to start with.
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A50854)
2000 GMC C7500...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
More info coming soon! (A49346)
More info coming...
