Ford 3000 gas
   / Ford 3000 gas #1
Tom Wells
I have a Ford 3000 gas and can not get it started. I have replaced the points, plugs, condenser and coil but am still not getting any fire to the distributor. Any suggestions.
Tom
   / Ford 3000 gas #2
Welcome Tom Wells
Do you mean you have no spark with the coil wire "safely" held above a good ground point and the engine turning over?
Do you have power to the coil?
   / Ford 3000 gas #3
remove the cap from the distributor and operate the starter. When the engine is turning the rotor inside of the dist will turn as well. If the rotor does not turn you have a problem.
   / Ford 3000 gas #4
first make sure u are getting fire to the coil and after u know u are getting fire to the coil then make sure u get fire going from the coil to the distrubtor not the distrubtor cap if u get it there pull the distrubitor cap and rotor and plate of and check your gap on the points and with all that off then the tractor over and make sure ur point or firing u will have a problem some where in that line most likely
   / Ford 3000 gas #5
yep.. ressitor wire may have let go.. or key switch is bad. can always jump from bat to coil to check this.
soundguy
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
2000 Toyota Tacoma 4x4 Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
