I have a Ford 3000 gas and can not get it started. I have replaced the points, plugs, condenser and coil but am still not getting any fire to the distributor. Any suggestions.
Tom
remove the cap from the distributor and operate the starter. When the engine is turning the rotor inside of the dist will turn as well. If the rotor does not turn you have a problem.
first make sure u are getting fire to the coil and after u know u are getting fire to the coil then make sure u get fire going from the coil to the distrubtor not the distrubtor cap if u get it there pull the distrubitor cap and rotor and plate of and check your gap on the points and with all that off then the tractor over and make sure ur point or firing u will have a problem some where in that line most likely
