ford 3000 fuel problem
   / ford 3000 fuel problem #1
Zeke1
Llano,Texas
Ford 3000
I have a ford 3000 tractor, wasn't used during the winter. I started it early spring. the fuel pump was leaking gas from the weep hole on side of fuel pump. I ordered new pump, installed it. the pump is pumping to much fuel to the carburetor. The tractor was running very good with the old pump on it. Has anyone had a problem like this. I am new to the forum, so I hope I posted this correctly. Thanks, Zeke
   / ford 3000 fuel problem #2
Sounds like the carb float or needle valve is stuck open. Might be able to clean and reuse but a carb kit is probably cheap enough. Make sure to clean all the parts so it doesn't gum up again.
Jim
Thanks, for the information. I have replaced the needle valve, and adjusted the carb float, everything seems to be in working order. I put a fuel gauge on the fuel line coming from the fuel pump. The fuel pressure just kept building up, until I released the pressure. I really cannot understand the problem. I am not a mechanic, but I have a lot of common sense on how to repair my on things when need be. I guess the new pump is pumping to much fuel to carb. I don't suppose there is any kind of adjustment from cam lobe to pump. If someone can figure this out I would really appreciate the info. Thanks, zeke1
   / ford 3000 fuel problem #4
I can not answer your question, but I would try a second new fuel pump to isolate the problem to either the pump or the carb.
The fuel pumps seem to be relatively inexpensive:
Ford 3000 Fuel Pump - F2NN9350AA
Also, you did not mention whether the old pump worked at all. If it did work in spite of the leak, I would reinstall and see if it still works will your carb adjustments.
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
