Ford 3000 Flow Control Valve Not Working Properly
   / Ford 3000 Flow Control Valve Not Working Properly #1
craig70032
Douglasville Ga.
ford 3000
I'm having a problem with my lift arm not wanting to stop in the upright position, it then blows the seals in my pump. The valve is not letting me control how high or how low the lift arm goes. I should be able to control where it stops. I've already changed the relief valve and this doesn't fix the problem. If anyone has any suggestions, it would be appreciated.
Thanks, Craig
   / Ford 3000 Flow Control Valve Not Working Properly #2
You don’t have a relief valve problem and you don’t have a flow control valve problem. The linkage that operates the 3pt control valve is faulty or the control valve itself has issues.
Thanks for the respond. Can it be that the control valve spring is bad?
7022 (A50322)
7022 (A50322)
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
