Ford 3000 Flow Control Valve Not Working Properly
   / Ford 3000 Flow Control Valve Not Working Properly #1
craig70032
Douglasville Ga.
ford 3000
I'm having a problem with my lift arm not wanting to stop in the upright position, it then blows the seals in my pump. The valve is not letting me control how high or how low the lift arm goes. I should be able to control where it stops. I've already changed the relief valve and this doesn't fix the problem. If anyone has any suggestions, it would be appreciated.
Thanks, Craig
   / Ford 3000 Flow Control Valve Not Working Properly #2
You don’t have a relief valve problem and you don’t have a flow control valve problem. The linkage that operates the 3pt control valve is faulty or the control valve itself has issues.
Thanks for the respond. Can it be that the control valve spring is bad?
71069 (A49346)
71069 (A49346)
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2013 John Deere 824K (A51039)
2013 John Deere...
