Ford 3000 engine
   / Ford 3000 engine #1
Turbofarmer
Milton keynes
Ford 3000
Have taken head off our 3000 was expecting to find burnt out valves because of chuffing sounds when running but valves all ok, any ideas what noise might be ?
   / Ford 3000 engine #2
Too bad you didn't ask this BEFORE you took the head off, when we could have actually had you do some diagnostic tests. :( ( that needed the head on! )
1, you could have done a dry then wet compression test. This would have told us the general health of the engine via dry compression, ballanced with knowing that if it is a low number, if it was rings or valves, or a head gasket.
2, If it was a gasser, we could have done ignition tests to see if the chuffing was cyl related, or moved.
3, if it was a diesel, we could do a similar injector test.
As it is now, do the valves all move correctly?
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
1266 (A50490)
1266 (A50490)
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
