Ford 3000 Diesel starter
   / Ford 3000 Diesel starter #1
gedwards6F3T
Smiths Falls, Ontario, Canada
Ford 3000 Diesel
How do I remove 3rd bolt behind starter next to block? Have removed battery plate for more visual access from above. I've tried positioning socket with wobble extension but there is little room for my big hands. Do I have more obstacles to remove? Losing patience in this -20 Celsius winter weather.
Gary
   / Ford 3000 Diesel starter #2
3/8" drive 6 point flex socket; 6" extension, ratchet. May want to remove the fuel filter, will probably help somebody that hasn't ever done this before.
Thanks Rick,
Will remove double fuel filters & hope for access to land swivel socket on head of bolt.
Gary
   / Ford 3000 Diesel starter #4
Don't put the ratchet on the extension till the socket is on the bolt head. A couple wraps of electrical tape (not too tight) around the flex joint of the socket will hold it almost straight if the joint is real loose.
   / Ford 3000 Diesel starter #6
ditto what rick said. AND, if you use 2 expensions, you don't even have to remove the fuel filter head, just loosen lines so it can move a lil.
ditto on swivel head sockets, or one of those click in u-joints. I used 2 6" extensions, plus a socket, plus a short 3" wobble extension. it's a PITA. almost as bad as the top starter STUD on a dodge ram. it uses 2 bolts and a stud. stud is on top, bolts on bottom. starter is right under engine, you literally go at it blind feeling around with an extension and socket that is stuffed with a wad of tape to keep the nut at the front. AND the electrical connections are ont he top of the starter too! BONUS!
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
(2) Drums of Car Wash Brush Soap (A51573)
(2) Drums of Car...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
