Ford 3000 diesel instrument cluster
   / Ford 3000 diesel instrument cluster #1
ron747
Bagdad
Ford 3000 diesel
I am replacing the instrument cluster on a 1975 Ford 3000 and having trouble getting the
bulbs to stay seated in the cluster. I can push the bulbs into the holes in cluster but nothing there to keep them in place.
Has anyone else had this problem or know of a fix?
   / Ford 3000 diesel instrument cluster #2
I havent taken mine out yet, but do they not do the typical 'push and twist'?
I am not replacing the bulb. I am replacing the cluster and trying to transfer the bulb/socket assembly into the new instrument cluster. problem is it doesn't 'connect' but just slides in unattached and slides out as you're trying to attach the new cluster to the opening. :(
   / Ford 3000 diesel instrument cluster #4
Maybe the holes in the new cluster are slightly larger than those in the old unit. The bulb assemblies should have a ring of small spring tabs that snap into the holes in the back of the cluster. Sometimes it's necessary to take a pair of needlenose pliers and bend the tabs outward a bit to enlarge the overall diameter providing a tighter "grip". I've had to do this a time or two.
thanks for suggestion but unfortunately the socket is made of plastic and will not bend outward without breaking.
Since this is a 1967 tractor with mostly original wiring I am considering buying a new wiring harness kit which includes the newer bulb sockets.
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
378704 (A51573)
378704 (A51573)
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2014 FORD F-550 SUPER DUTY SERVICE TRUCK (A52472)
2014 FORD F-550...
