Ford 3000 Diesel Block Heater
   / Ford 3000 Diesel Block Heater #1
Paystar
Elite Member
Ontario, Canada
Kubota B2620
My 67 Ford 3000 has a block heater in it, but it is missing the cord. I don't know if I can find a cord that matches it, but if I want to check to see if the element is even any good, I just need to check resistance right?? Is there a value of Ohms I should be looking for?
I looked at several aftermarket block heaters for a Ford 3000 on google and they seem to range from 600 to 750 Watts. But most have an o-ring. Only one I found is threaded and that's what this one looks like? Does it just unthread?
Just wondering what my options are.....find a cord, replace whole thing or do something else?
   / Ford 3000 Diesel Block Heater #2
Yes, you can check if it has resistance to see if still intact and possibly working.
Socket for the cord looks conventional to other heaters.
Here is a block heater replacement:
So that is the right one then. Thanks a lot TractorTech.
Not going to be running the old tractors during the winter, but I hate it when something is incomplete or not functioning.
So what should I see for resistance if I check the one that's in it?
   / Ford 3000 Diesel Block Heater #4
Thanks again. I'll check it out.
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
1992 Peterbilt 379 Tandem Axle Road Tractor (A47477)
1992 Peterbilt 379...
A-FRAME (A55745)
A-FRAME (A55745)
