Ford 3000 clutch question
   / Ford 3000 clutch question #1
dave76574
When I step on the clutch to engage or shift the gears or engage the PTO, there is some grinding of the gears (especially with the PTO). I have to jam the PTO to engage it because the gears are still turning. If I engage the PTO with the engine off it is too much load to start.
Any suggestions on how I would repair this?
Are the repair manuals a good guide for this kind of repair?
Thanks for all the good advice in helping us get our tractors up and running!!
Dave
   / Ford 3000 clutch question #2
Either you need to adjust the clutch(s) OR the clutch(s) may be sticking. Start off by adjusting main clutch, then pto clutch. Service manual will walk you through the proceedure.
I don't like I&T Manuals. Too much left out. Too much erronious info for my liking. But... They'll get you through a clutch adjustment without much fanfare. I'd rather have the Ford manuals myself. (Owners, Service, and parts)
   / Ford 3000 clutch question #3
Sounds like the clutch isn't fully disengaging. If it was working normally and suddenly started doing this, there's a chance the clutch plate is coming apart. A chunk of clutch lining could be trapped between the clutch disk and the flywheel or pressure plate. This would keep some power going to the output shaft even with the clutch disengaged.
Try adjusting first, though.
Bob
2013 MACK GU713 (A50854)
2013 MACK GU713...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2008 Ford F-450 4x4 Tow Service Truck (A49461)
2008 Ford F-450...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
CM Trucks Utility Bed (A49461)
CM Trucks Utility...
