Ford 3000 Charge Light Staying on
   / Ford 3000 Charge Light Staying on #1
Craigschme
Hutchinson, MN
Ford 3000
Hi. I have a Ford 3000 and recently, the charge light stays on when I start it. It will eventually go out, but it is taking longer each time and I have to increase the RPMs to almost wide open now. The tractor starts fine and runs fine. Is the generator going out?
Thanks for any help I can get
   / Ford 3000 Charge Light Staying on #2
Could be your battery is on it's last legs, or your voltage regulator, or your generator or all three. it could be your starter draw is excessive so it takes longer to charge the battery. You need to do some diagnostics to sort this out.
   / Ford 3000 Charge Light Staying on #3
I'd opt for worn brushes if you haven't visited the charging system in the last 10 years. My 3000 just got it's first set of brushes on a replacement generator after about a thousand hours, off ebay. The regulator is still OEM.
Battery problem would be sulphate and that would amount to internal resistance in the battery which is in series with the charge/discharge current. It'll make for a faster "apparent" charge and shut your light off faster but would result in less storage energy when the battery told the regulator it was full.
   / Ford 3000 Charge Light Staying on #4
if you have a "generator" and not an "alternator" on tractor. do you need to "meh" forget the term. run a wire between battery and F terminal on generator. when ever you disconnect battery? if you do not not do this on old systems, the generator may not have correct charging.
to OP (original poster) wait for others to respond.
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
