Ford 3000 cav injector pump W and U stamp
   / Ford 3000 cav injector pump W and U stamp #1
ccobb
ford 3000
Putting my 3000 back together after burning a piston. Did not mark the injector pump lines when I tore the engine down. Need to verify the lines location on the injector pump.
   / Ford 3000 cav injector pump W and U stamp #2
There should be a dowel in the drive gear that fits into the slot in the injection pump drive hub.
   / Ford 3000 cav injector pump W and U stamp #3
It's kinda hard to see but this picture shows the dowel between two of the bolts.
   / Ford 3000 cav injector pump W and U stamp #4
This one's hard to see also but the timing mark on the pump lines up with the 0 on the block.
   / Ford 3000 cav injector pump W and U stamp #5
I have to have the pump # inorder to look it up to tell u which pump cylinder is #1..
The numbers are 3233F 640 the 640 is crossed off and 639 is stamped in. The lower number is ROA11TT
   / Ford 3000 cav injector pump W and U stamp #7
I just saw your latest post.. actually stumbled on to it..
I don't get notifications until 3:00am the following day..
I'm having trouble getting into the CAV server..
The bent lines should be an indication of what goes where..?? especially seeing theres only 3.!!
I'll let u know when I get u an answer..
   / Ford 3000 cav injector pump W and U stamp #8
Should be easy to mock them up if you didn’t bend them out of shape when you removed them.
unfortunately the prior owner decided to make them straighter
   / Ford 3000 cav injector pump W and U stamp #10
Ok. I guess I didn't understand the first time.
On my 1973 4000 SU, the line that comes from the top, back of the pump goes to #1, front of engine. The line that comes from the front of the pump, on the side goes to #3. The line that comes from the bottom goes to #2.
Fuel Tank (A51573)
Fuel Tank (A51573)
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
Wright Sentar (A50120)
