Ford 3000 3pt hydraulic issues
/ Ford 3000 3pt hydraulic issues #1
irl3r
JD 870
Hello All
my 3 pt only works while engaging one of the asc remotes . 2200 psi at pump only while remote handle in lift position.I know this sounds impossible.
this started after total pump and top lid rebuild. suction filter removed and cleaned. Discharge filter new. all orings replaced. New fluid. my 3pt initially worked but wondered up and down with attachments. replaced cam follower pin at lift cylinder,it was badly worn. Now has 3pt has hiccups unless the remote is in the lift position. I’ve double checked everything and just can’t find the point of failure l.
Any suggestions will be much appreciated
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2000 Freightliner Classic XL T/A Sleeper Cab Truck Tractor (A66736)
2000 Freightliner...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
