Ford 3 Cylinder Tractors, Best Coolant to Prevent Cavitation
   / Ford 3 Cylinder Tractors, Best Coolant to Prevent Cavitation #1
JLMissouri
Macon, Missouri
1952 8N, Jubilee, 860, 861 Ford 2000, Ford 4000, Ford 8000
I am planning on doing some preventative maintenance on my Ford tractors. I have seen answers all over the place on the best coolant to use to prevent cavitation. Is the coolant sold by New Holland the best, or is the long life antifreeze sold everywhere have the same additives and is it just as good? If it matters I have a Diesel 2000, gas 4000 and a diesel 8000.
   / Ford 3 Cylinder Tractors, Best Coolant to Prevent Cavitation #2
It's probably not a bad idea as most all modern coolants contain those additives. In the For What It's Worth department, those models were never known to exhibit cavitational erosion which mostly happened on high horsepower models. The consequence was cylinder wall failure on the thrust side of the cylinder. It was more of an issue on parent bore blocks vs sleeved blocks.
   / Ford 3 Cylinder Tractors, Best Coolant to Prevent Cavitation #3
I run regular 50/50 coolant, but add New Holland coolant conditioner as recommended.
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
