Ford 2N only runs with choke pulled all the way out
   / Ford 2N only runs with choke pulled all the way out #11
Make sure that you have the primary ignition circuit performing correctly. You'd be surprised how many carburetor "problems" are eventually found to be a weak spark. You need a FAT, BLUISH-WHITE SPARK, the color of lghtning.
Are you sure you have the carb adjusted properly. Make sure you don't have an air leak around the Carb's metering section. The usual culprits are worn throttle shafts, leaking gasket at the carb/manifold interface, cracks or rusted spots in the intake manifold and a leaky manifold gasket.
If you have the requisite FAT, BLUISH WHITE SPARK, AND the carb is adjusted properly, AND you have no air leaks around the carb's air metering system, then a good cleaning of the carb is called for.
UNUSED LANDHONOR WEBBING SLING (A50460)
UNUSED LANDHONOR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A50459)
KNOW BEFORE YOU...
2017 Mower Max Flexwing Mower (A48837)
2017 Mower Max...
2017 Big Tex Trailer Trailer, VIN # 16VGX2823H6058998 (A48836)
2017 Big Tex...
Willmar 4300 Wrangler Loader - Runs and Operates, Oil Loader, Ready to Load (A50397)
Willmar 4300...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
